It is currently Sat Jul 19, 2025 6:59 pm
 Post subject: veneering question
PostPosted: Wed Apr 21, 2010 1:55 pm
Hey everyone,
I have a veneering quandary I'm hoping to get answered by you pros. How would I go about slapping a burl veneer on a dome topped instrument? The instrument in question is an ibanez sabre series I am retopping with a nice walnut burl veneer. Flat top-easy. I'm worried about a domed top, though. Will I get wrinkles around the waist, or will the veneer "stretch" over the highest point (bridge area) to allow for a flat, wrinkle-less surface? Do I HAVE to use a vacuum set up, or is there a way to evenly disperse weights around the top? So many questions from the lurker....
Thanks in advance!
 Post subject: Re: veneering question
PostPosted: Wed Apr 21, 2010 3:07 pm
First name: Stephen
Last Name: Ziegenfuss
City: Jackson
In my experience:
1. Vacuum setup is a must
2. You have to be skilled in working out potential wrinkle areas during vacuum application. If the top is too curved for the burl to distibute the stress / deformations easily, it will tear/ wrinkle.
It is a difficult thing. The first time I tried to do this, I ended up sanding the top off and laying on a full 0.5" of the wood I wanted in order to recarve the top. I have never turned back from that method.
Let us know what you try!
Stephen
www.ziegenfussguitars.com
PostPosted: Wed Apr 21, 2010 4:33 pm
Last Name: Abercrombie
I've never done this, but if I were to try, I think I'd pre-treat the veneer with a 'softener' like SuperSoft II.
It might help.
I've done quite a bit of (flat) veneering as well as curved laminations, and I agree 100% with Stephen's comments. [:Y:]
PostPosted: Tue Apr 27, 2010 1:29 pm
Veneer has very little stretch. I think what you are proposing is not possible.
When I make archtop plates with veneer, I cut "darts" at a few points around the lower arch to allow the veneer to conform to the plate. But this is utilizing a vacuum bag and a two part form.
